Confirmed Hughes System Error Costs Me Hundreds (Token111 error)
Hello,
It has been a while since we heard from you so this thread will be closed. If you have any further questions or concerns please create a new thread.
Thank you,
The tokens I have were collected over a few years. I had some when I came from my old plan, got a few from the two outages this year (Jan and Sept), and got some for doing some speed testing in the past.
When I upgraded to Gen5 I chose the 20GB plan, and it has been enough for me. If I still had Gen4 and upgraded to Gen5 now I wouldn't have the choice of a larger plan, as the 20GB plan is the largest they are offering on my beam these days. I have yet to need any of the tokens I have, though they're ready to go, just in case. I should just suck it up and go on a bit of a streaming spree! :p
There's no 50GB token purchase available, though if there were the price would be the same as two 25GB token purchases, as when you break all the options down the tokens are $3 for each GB, regardless of how much you buy. It's a little odd that they don't give something off for the larger purchases, like maybe offering the 25GB token purchase for $70, or even $65, but they don't, unfortunately. :(
