VortecCouple
9 years agoNew Member
confused about data usage
My wife and I recently moved to a different home. We were previously customers of Comcast but was forced to use satellite service as we are now in a rural area. We signed up for HughesNet on 10/14/17...
9 years agoDistinguished Professor IV
I'm wondering if maybe it was a 10Mbps plan, as doing a Google search shows that they may have, or have had, something like that. Something called Comcast Internet Essentials.
BirdDog
9 years agoAssistant Professor
VortecCouple seems to be conflating data amount with speed, two very different things. Again like you say, should repost under different topic like Tech Support or Products and Plans, this is the billing section.
VortecCouple, do you have a problem with your billing?
- HughesNetSucks49 years agoSophomoreNeither of you were helpful at all to VortecCouple. Aren't you here to help? Telling them "post your comment in another category" does nothing for the customer, and they should be your top priority.
First, this is not the tech support site. Data usage is a tech support issue.
Secondly, please stop spamming.
