Data Alotment question
If you're on the 20GB plan, you should not use more than an average of a little over half a GB per day.
CWM030 wrote:
EDIT: I am on the 20 gig plan too and I dont think its going to be enough :L
I try not to.. But with my pc hardwired in, 2 phones, and Google Home I might use a almost gig a day.
There's a bonus period between 2am and 8am where you should have an extra 50GB for the month. If you can tell your devices not to auto-update, then manually do it before 8am, you can significantly drop your anytime usage.
EDIT: MarkJFine posted when I was typing this. :)
Just be aware you're going to run out of data if you use that much a day. You may have to buy tokens or move some things (like downloads) to the Bonus Bytes portion of the day (2 to 8 AM local time). We all get an extra 50GB for use during those hours.
CWM030 wrote:I try not to.. But with my pc hardwired in, 2 phones, and Google Home I might use a almost gig a day.
