TDR
5 years agoNew Member
Data limits
I don't understand! When I first signed up with HughesNet I was paying $50 per month ... but ran out of data monthly. So I switched plans and began paying $70 per month .. but continued to run out ...
If you run our of data, you will need to see where you're using the data, and budget the available data so it will last all month. If you get the 50GB plan, you can use an average of 1.6 GB per day. If you use more, you will run out of data. Streaming eats up a lot of data very quickly, so if you're streaming, you will need to keep an eagle eye on your data so you don't run out before the month is over.
