ETF Cost Question
Here's the reduction by month. So it looks like you're correct; if you cancel during the last month, then the ETF is $85.
- Ryan114334 years agoJunior
Oh of course when that time come I return the modem including AC adapter and the radio transmitter? or be charged 300? Is the radio transmitter on the dish?
Ryan11433 wrote:Oh of course when that time come I return the modem including AC adapter and the radio transmitter? or be charged 300? Is the radio transmitter on the dish?
Yes. The instructions for removing the radio, which will also be included in the equipment return box they send, are here.
If, for whatever reason, you're not able to retrieve the radio yourself, they can send a tech to remove it for you, but there is a charge. I think it's $125, but I'm not 100% on that.
thank you for the information I'm just getting prepared so I will know what to do when that time come that I move out back to Jacksonville in Mandarin area. Is Hughesnet supported in those area because I know Comcast uses landline and it does have outages almost all the time. Zip Code is 32223.
