cybo54
5 years agoJunior
Is it still possible to upgrade to Gen5 and keep our current HT1100 modem? If yes, what all does this entail, and what costs would be associated with such an upgrade? We're currently on the Gen4 10G...
Good morning cybo54,
cybo54
5 years agoJunior
We can't edit posts anymore??? If not, apologies for above formatting w/ everything squished together, it was not that way when I posted
