Good morning cybo54,
They send you a new modem for Gen 5; I don't think you can use the old modem with Gen 5, but I could be wrong. As for editing, you can still do so. Just click the 3 vertical dots on the right hand side of the post area and click "Edit." The HN reps on this site will be able to answer your other questions.
- cybo545 years agoJunior
Back when we moved to Gen4, 2016 or 2017 I think, Amanda or Liz said we could use HT1100 for Gen5 later.
Now, that way may be "fake Gen5", and maybe not so fast, I can't remember how it was explained, but our main goal here is 20GB daytime a month instead the 10GB we have now.
Hopefully this is still possible as I know it will keep our end costs down that way
Thank you for the info on editing. I would have seen that, but until you mentioned it was not there, I now see it's blocked by "uBlock Origin" I didn't see until I turned that off.
I think that if they keep you on the old satellite you can use the old modem. If no one else answers your question, the reps will be back on Monday and they will, or you can call customer service or use the chat service. I hope it's possible for you to do what you want.
You're welcome! Wow, I didn't realise that UBlock Origin blocks the 3-dot menu. I wonder why. I use a different app and it doesn't block the edit function. I guess you'd have to unblock UBlock if you want to use the functions listed in that menu...
Upgrading to Gen5 would require the usage of the HT2000W modem. Depending on the age/type of dish you have, it may require a tech visit to complete the upgrade, even if it's only to reverse the polarity of the "eye", but whether that or any dish adjustment would be needed only a rep can say.
I had the same type of problem when I was trying uBlock Origin out for a few months a year or so ago. Everything was fine, then all of a sudden a bunch of options were missing, including the option to edit posts. It took a bit to figure it out, but once I did I went back to Adblock Plus, which is what I had gone to uBlock Origin from.
maratsade- Yes, hopefully Liz or Amanda replies this week, those are the two who's always helped us in the past
I'm sure someone will reply once the week gets going, not in any hurry so it's OK to wait.
Yes, I just disable ublock as needed.
GabeU- Why do you say that?
It didn't used to require different modem, and we could have switched to Gen5 back at launch with current setup (was told that at the time anyway), but we did not due to it still being in beta phases back then.
Same here, I used to use Adblock plus too, but it was giving me issues with something (can't remember), so I moved over to uBlock
