Good morning cybo54,
- cybo545 years agoJunior
Liz - Thank you for the reply!
I think we own the HT1100 modem, or at least do not pay any lease fees for this, would there be lease fees on the HT2000w if sent for free?
For the HT2000w, would a new dish install be required too?
If we can stay on HT1100 is a truck roll required, or is that a requirement no matter what due to needing a dish realignment even on HT1100?
The main reason we wanted to stick with the HT1100 was to avoid truck roll costs, but now that I asked above I guess that may be required even if we stayed on HT1100 :(
- Liz5 years agoModerator
Hi cybo54,
Since you're a purchase customer, there would be no lease fees for your HT2000w.
Only Gen 3 or other legacy customers would require a truck roll if they upgrade to Gen 5. I've sent you a follow up PM as well.
Great and great, thanks for the answers!
