Good morning cybo54,
Hi cybo54,
Since you're a purchase customer, there would be no lease fees for your HT2000w.
Only Gen 3 or other legacy customers would require a truck roll if they upgrade to Gen 5. I've sent you a follow up PM as well.
Great and great, thanks for the answers!
