Good morning cybo54,
GabeU -
I think it was right around launch, we were not invited to beta but it was still "in beta" so to speak and the official beta testing was still going on too.
At that time, there were many users on the forums using HT1100 and getting Gen5.
I think even "some" new installs were going on on HT1100 too, depending on location if I rememeber correctly.
And on the forums it was referred to kinda as "fake Gen5", you got the same speeds, plans, prices etc, but not "officially Gen5".
Speeds we get now are same basically the same as Gen5 advertised, our concerns are more about the larger 20GB daytime a month more than anything else.
We tend to run out of daytime bandwidth in 1-2 weeks usually, and end up spending 2 weeks or more a month with slower daytime speeds.
Thank you for your replies!
Are you sure you're not thinking of the discussions prior to release and people asking about whether they would need to upgrade? I remember a slew of those. But I've never seen a discussion, topic or reply, post Gen5 release, that stated anything about people being able to upgrade to Gen5 while keeping their HT1100 modem.
Every time people have asked what an upgrade to Gen5 would entail, the one constant has always been the inclusion of the HT2000W modem. For some people, that's the only thing they need for the upgrade, as both the ES17 and ES19 satellites can provide Gen5 service.
Or, might you be thinking of this post (or topic), which discusses the future (at the time) plan of using the HT1100 with Gen5 on the ES17?
- cybo545 years agoJunior
GabeU- I'm not 100% sure? But yes, there was discussion about the two different satellites then too
I just remember that we were told at the time we upgraded to Gen4 that we could get Gen5 either if we wanted, and that it would use same modem
It's not a big deal, Liz said we could use HT1100 too, but it's not ideal, since the new modem is more optimized for Gen5 and we should go ahead and use it anyway since it's sent out free w/ upgrades
What is modem dependant on Gen5, other than the built in Wifi router?
Our main concerns w/ continuing to use HT1100 was to avoid new modem purchase, and or truckroll if new modem was 100% requirement.
But seems that's not the case in any regard, HT1100 technically could be used, but also no fee for the new modem and no truckroll required, so might as well go that route.
cybo54 wrote:What is modem dependant on Gen5, other than the built in Wifi router?
To be honest, I can't remember for sure. I think it may have something to do with data compression, though that's more a guess. There was a thread a while back (at least a year I think) where something was mentioned as being different and specific to Gen5 (besides the modem's WiFi), but I can't for the life of me find it, nor remember the gist of the topic itself.
I could be entirely wrong and it may have been something more specific than dependant.
Liz- seems I cannot reply to PM right now??? >> You have reached the limit for number of private messages that you can send for now. Please try again later.
To answer your last PM, yes that is our correct address
* Edit - Please delete, I guess it was a 30 second or one minute wait issue, replying to PM's too quickly or something?
- Liz5 years agoModerator
Hi cybo54,
I got all your PMs, yes there's a limit on how many PMs you can send in a certain amount of time; this is to prevent spam/abuse. I'm glad we addressed your concerns and got you upgraded to Gen 5. Your new modem should arrive next week so please look forward to that.
The community is always here for you so drop by any time if you have other questions or concerns.
Yes, sorry, I thought it was a daily limit at first, right when you asked me about address I could not reply to that PM. So I posted the reply above.
All sorted now, I was just replying too quickly in PM's :) Thanks again for your time and help on this upgrade!
We'll be on the lookout for the new modem! Have a great weekend!
The system can get a little confused sometimes too. If you try to send a PM and on your first attempt you get a message that HTML has been changed, especially when it's a reply to a PM, and even further, when it contains all or part of the message being replied to as a quote, there's a very good chance of getting that 'limit' message on the subsequent 'send message' attempt.
If this is/was the case, you can normally wait about five or ten minutes (with the message still open and waiting), then send the message through successfully.
