Good morning cybo54,
Yes, sorry, I thought it was a daily limit at first, right when you asked me about address I could not reply to that PM. So I posted the reply above.
All sorted now, I was just replying too quickly in PM's :) Thanks again for your time and help on this upgrade!
We'll be on the lookout for the new modem! Have a great weekend!
The system can get a little confused sometimes too. If you try to send a PM and on your first attempt you get a message that HTML has been changed, especially when it's a reply to a PM, and even further, when it contains all or part of the message being replied to as a quote, there's a very good chance of getting that 'limit' message on the subsequent 'send message' attempt.
If this is/was the case, you can normally wait about five or ten minutes (with the message still open and waiting), then send the message through successfully.
