misleading info given by sales call and now need to pay early termination fee, HELP!
To expand on maratsade's information, the instructions for the speed tests that the reps may need are as follows...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform 3-5 tests during different parts of the day, then share the account results link with us here.
-If testing upload instead of download, please use the manual 4MB size upload test file
For a more in depth guide on running the tests, please visit: http://customer.kb.hughesnet.com/Pages/7001.aspx (due to being an older page, the test sizes are incorrect for Gen5 (please use the test sizes listed above, in bold, for Gen5)).
If you are unaware of how to disable the WiFi in the HT2000W, please see "How do I manage my built in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
thank you GabeU! This was very informative. I will open a account with testmy.net and start recording the speeds. I did record the speeds i was getting from Speedtest. But if it’s required from test my.net i will do that. I just upped our data so our speed is back to normal for now.
While speedtest is okay for general knowledge, it's not accepted for troubleshooting due to the way in which it tests. Testmy.net is requested because a specific size is used for each test, keeping the testing parameters identical with each test performed, and because of the way it handles the higher latency. It also gives more information with each test result.
On a side note, speedtest uses a LOT of data per test, so I avoid it especially because of that. Maybe not that much when out of data and your speed is throttled, but when you're not throttled it can use 70MB or more per test. I just ran one test and it used 81MB.
- debbie.jean.bro7 years agoAdvanced TutorHi @branbomn,
I highly suspect your issue was being in FAP (Fair Access Policy, meaning when they slow you way down because you have run out of data).
I think this for two reasons. First, you mentioned the first month went fine and just a few days into month two you were running super slow and couldn't stream. Well, you get unlimited data the first month, so that makes a lot of sense.
Second, you mentioned you upped your data and therefore your speeds were back up to normal. That tells me you had run out of data and were being throttled, as it is called. Once you purchased more data, your speeds were returned to normal.
It is true what maratsade, GabeU, and your sales rep told you, in a technical sense. When you are in FAP, it is mainly just good for text browsing--you can read the news, check your email, etc. But it's not much good beyond that because it's just so darn slow.
If you want to stream something short on Youtube, you can probably do it in low resolution, if you pause it at the beginning and let it load (give it LOTS of time to load!). But if you want to stream a movie, forget about it, unless you have the patience of Job! You'll be buffering every 15 seconds and it will take you 4 hours to watch a 90 minute movie (in my experience ).
OPTIONS:
• Buy more data
• Stream movies during bonus time (I think it's 2:00-7:00 AM most locations)
• Set your device to download movies during bonus time and then watch them whenever
• ALWAYS watch video in the lowest resolution available! There are other threads on here that explain how to do that.
• Search the history here and learn all the hacks for using less data. Just watching in low res vs. high res can increase your streaming time by a factor of three or more!
• Do Netflix the old-fashioned way, via disc by mail.
With Hughesnet, you cannot watch unlimited movies because you have limited data. However, you CAN stretch the data you have immensely by learning some simple tips and tricks!
I hope this helps.
Sincerely,
Debbie- maratsade7 years agoDistinguished Professor IV
"When you are in FAP, it is mainly just good for text browsing--you can read the news, check your email, etc. But it's not much good beyond that because it's just so darn slow."
Actually, people who have been in FAP have reported that they can still stream, as long as it's in low def.
