Not streaming
If you are trying to stream in anything higher than 480p, you'll most likely need to turn off, or snooze, the Video Data Saver.
Keep in mind that streaming is a data intensive activity, especially when done in HD. Netflix's data amounts state 300MB per hour in LD, 700MB per hour in SD, and 3GB per hour in HD.
Also, during the first twenty days your HughesNet service is in what's known as a "relaxed bandwidth state", meaning that your monthly data allotment is continually reset during this time. HughesNet does this as a courtesy in order to allow new customers to update/upgrade their devices to current without it affecting what would be their normal monthly data allotment, as those activities can use a LOT of data, especially if the devices haven't been connected to the internet in a while. After the twenty days the continual data resets will end and the data you use will be counted like it normally would. The relaxed bandwidth state is mentioned in the Welcome email sent by HughesNet, but I mention it here because people often don't notice, or bother to read, the Welcome email.
