Ricky21613
5 years agoSophomore
Plan change
I want to change my plan. I went in to do that online. I check the box to not extend my contract. Screenshot below. Then when I go to checkout I get a prompt that if I proceed I will enter a contract...
Good morning Ricky,
The issue with the service plan site should be fixed now. Can you please confirm when you have a chance?
Ricky21613
5 years agoModerator
Thanks Ricky! OK that is unusual, from the screenshots, it appears that despite selecting the $59.99 option, the $49.99 option ends up in your cart, hence the commitment disclaimer. This happens every time?
- Ricky216135 years agoSophomore
Yes, every time. I have repeated it at least twice to get the error.
- Liz5 years agoModerator
OK thanks! I'm escalating this along with the screenshots to see what's up. I'll keep you updated.
Okay. Thanks Liz.
