Purchased tokens not showing up
Typically, the tokens are added immediately. Don't fret; it the tokens are still missing next week when the HughesNet reps come on the site, they will add them manually.
To be sure, check your account, and restart your modem.
- jallenhere4 years agoSpectator
So, if they don't show up until next week am I slowed down until then?
Just in case, are you looking at your Service Plan data or the Token Data? Token Data goes into its own data bank. It doesn't get added to your Service Plan data.
You should see it in the "Data Tokens Available" or "Token Data" or similarly titled line wherever it is you look at your data levels.
- maratsade4 years agoDistinguished Professor IV
jallenhere wrote:So, if they don't show up until next week am I slowed down until then?
Not necessarily. Follow GabeU 's instructions and if the tokens are still not showing, call the 24/7 800 number.
Ahhh....so, it doesn't actually change my data that is available on my usage screen? I see it says that I have 15.4 GB tokens available on my usage screen. No worries then, thank you!
