10 years agoDistinguished Professor IV
Question about D-Link router settings...
I just set up a new D-Link router, as my Netgear router was getting a little temperamental. The settings are nothing like my Netgear settings, which actually had a program to get into them. With th...
C0RR0SIVE
10 years agoAssociate Professor
WAP? You mean WEP? Most routers have removed the option to select WEP based encryption because of how easy it is to break.
