9 years agoDistinguished Professor IV
Question about D-Link router settings...
I just set up a new D-Link router, as my Netgear router was getting a little temperamental. The settings are nothing like my Netgear settings, which actually had a program to get into them. With th...
Should I use the setting mentioned above, AUTO-WPA/WPA2, or should I use the "WPA2 Only" setting in advanced settings?
