Purchased tokens not showing up
jallenhere wrote:So, if they don't show up until next week am I slowed down until then?
Not necessarily. Follow GabeU 's instructions and if the tokens are still not showing, call the 24/7 800 number.
Ahhh....so, it doesn't actually change my data that is available on my usage screen? I see it says that I have 15.4 GB tokens available on my usage screen. No worries then, thank you!
Not your regular data, no. Right now, if you're out of plan data, it should be drawing from that Token Data. If you still have some Service Plan data, but are getting close to running out, it will automatically switch to drawing from the Token data when you do run out. The Token Data always shows in and is drawn from its own data bank (Service Plan Data, Bonus Zone Data and Token Data).
Happy to help. 🙂
Edit: Just to add, and in case anyone else reads this, the schedule for data usage is as follows, with the following data bank automatically kicking in when the prior is exhausted...
8AM to 2AM: Service Plan Data > Token Data > FAP
2AM to 8AM: Bonus Zone Data > Service Plan Data > Token Data > FAP
FAP stands for 'Fair Access Policy', which is the throttled state your service enters when all applicable data in the particular time period has been exhausted.
