Want to cancel after 6 Weeks
Thanks again, Gabe. I appreciate your help.
I'm going to go ahead and tag the reps, too. They'll almost assuredly see this thread without me needing to do so, but they're a busy bunch, so I just want to be sure that they do. :)
- Liz7 years agoModerator
Good morning Willaurean,
Thanks for posting. I saw your other thread before I saw this one. I checked your account again this morning and I see that you reactivated your service, so let's address your data concerns. Currently you are being subject to the Fair Access Policy, so that's why your speeds are reduced. I sent you some complimentary tokens so we can troubleshoot without worrying about the reduced speeds.
To use your data tokens, access your Usage Meter (the application or online).
Click the Buy Tokens button.
The next screen will show you the number of tokens available for use.
Click the Use link next to the the number of tokens you have.
This will increase your TOKEN BYTES AVAILABLE amount, not your Anytime Bytes, and restore speeds.
You can use these tokens at your convenience when you have time to investigate your unidentified data usage. GlassWire is a 3rd party program that's been suggested by other community members to help you determine what on your computer is connecting to the internet and using your data. This is a helpful tool since we cannot determine exactly what is using your data.
If you rather tackle your speed concerns instead, use a token so you can run some speed tests for us to evaluate.
Please create a testmy.net account and run 3-5 tests during different parts of the day. Post your test results link here in your thread.
-use the 25MB size download test file ONLY
Hi Willaurean,
It's been a while since we last heard from you, so we will close this thread. If you still have concerns, please start a new thread and include a detailed explanation so we can more effectively help you.
