Unhappy2
7 years agoFreshman
Work from home and latency problem with VPN
Hi, I have posted here before regarding not being able to work from home due to the latency problem and logging into work thru a remote connection VPN. I only had Hughesnet for less than 30 days and...
Though Amanda may see this, it may also be a good idea to go into your PM section and reply to her previous message to you. That way, you can be sure that she knows of your request for help. If you don't know how to do so, click on the little envelope on the upper right while signed into this community, then click on the title of her previous message to you. Then, while reading the actual message, you'll see a reply button on the lower right, which you can click on to continue the conversation with her. When you send her your new reply message she will get a notification.
Keep in mind that the reps are on M-F from approximately 8AM to 5PM EST.
Unhappy2
7 years agoFreshman
Great thanks for that.
