We have a problem with our HughesNet phone service for the past 2-3 weeks. After 8-10 minutes or so the call drops. Sometimes we cannot reestablish the call without trying 5-6 times; then when we reestablish the call it drops within 2-3 minutes or less.
Sometimes, after dropping the call, we will get a phantom ringback (caller ID shows the number we were just talking to) as though the system is trying to reestablish the connection. When we pick up, it’s just a dead line.
It happens at all times of day, but seems to be worse in the evening, or perhaps that’s when we tend to be on the phone with family and friends.
In any case, this is making it very difficult to do business during the day or call our daughter in the evening.
This problem did not arise until 2-3 weeks ago; prior that that it was fine for 9 months, so I would assume that the handset equipment, wiring, setup, and configuration are not the problem. Perhaps the voice adaptor?
I have done numerous power cycles of just the phone adapter and of the whole system; doesn’t seem to make any difference.
Can we run some remote diagnostics to check the modem and ATA?
MODEM
MODEM
MODEM
MODEM
- LizModerator
Hi DocT,
I see it's your first post here, so welcome to the community! Thank you for the useful information, this helps. I ran diagnostics and the equipment looks fine. I've escalated your case to our VOIP team to see what we can do for you. I'll reach out when I have an update to share.
- DocTFreshman
Thanks for the quick reply. Let's see if we can make it work again!
- DocTFreshman
I haven't heard from the VOIP team.
Last night, our first call was dropped after about 12 minutes. The phone began ringing repeatedly as though the person we were talking to was trying to call back (she wasn't) and when we would answer, the line was dead. Hang up. Repeat. I turned off power to the ATA to make that stop. After that, we could make a call and it would last a minute or two before disconnecting.
I hope to hear from the VOIP team soon. We have no cell phone signal at home, so we can't really call customer service.
