For anyone else that may be comparing their HN data usage to their 3rd party router data usage....
Resetting in a little over four hours. Difference, at present, is 1,199MB.
- macsociety8 years agoAdvanced Tutor
I think it is a big enough difference though at over 1GB in a month on loss of data the end user can use. I wack through mine fast so having the extra 1GB would be nice. ;-)
TJ
GabeUwrote:Resetting in a little over four hours. Difference, at present, is 1,199MB.
macsocietywrote:I think it is a big enough difference though at over 1GB in a month on loss of data the end user can use. I wack through mine fast so having the extra 1GB would be nice. ;-)
TJ
I have no doubt that, were I closer to hitting the wall with my data each month, I might be more vocal about a 1GB+ difference.
I've also got to make sure that it's not just my router. I'm thinking about seeing if my folks' D-Link router has a data counter, and swap mine with theirs if it does, just for the time being. That way I can see if the discrepancy is just with the Netgear router or if it's with the D-Link, too, and therefore, real.
