Silviron
7 years agoSophomore
HN7700S Modem to replace HN7000s on Pro Plus plan?
OK, I FINALLY got the modem from the Amazon seller (as discussed in this thread in the tech section: Modem constantly resetting ) (didn't actually ship until two weeks after he sent me the tracki...
Thanks, Gabe to both things.
Will Do..
I think you'd probably be better off asking if the HN7700S modem will work for you in Tech Support. Visibility wise.
From what I've seen you won't be able to use it, but you never know.
If it doesn't work out, contact me through PM (the little envelope on the upper right of the page) after the new year and I'll send you this one. I'm thinking now that, rather than the techs reusing it, I took the base off in order to make it better fit on a shelf, but I haven't been able to find it. Still, again, the base on your HN7000S would fit it. There's a little clip on the bottom that holds it in place.
- Silviron7 years agoSophomore
Will Do..
