Hi rossalissalove,
Thank you for your patience while your case was worked. I pulled up your account and I see that Wade has already issued a dispatch to replace the radio and modem. Your Dispatch is currently scheduled for Thursday, Jun 28, 2018 between 02:00 PM-05:00 PM. I'll privately message you your local tech's contact info so that you can coordinate if that time does not work out for you.
I went into the settings and unchecked the boxes you told me to and the 5g actually showed up but I couldn't connect to it. But then a few minutes later I went back in and rechecked those settings and it disappeared again. And the "12.1.9 -- A transmit problem has occurred" message has popped up again. Can't we just get a new modem or something?
I just tried unchecking and rechecking those wifi settings again and this time the 5g popped up after I rechecked all the boxes. I tried to connect to it again but it was showing there was no signal. I enetered in our password for it and it said there's no connection and then the 5g disappears again.
