Liz-
-Kent
Hi coppcabin,
I see it's your first post here, so welcome to the community! Thanks for reaching out, this sounds very peculiar. As Gabe previously stated, I'm curious as to what power source the HughesNet modem is connected. Are you connected to a UPS? A power strip? A wall outlet?
If you're not already connected to a wall outlet, please do so to see if you notice a difference. The diagnostics I've run on your site don't indicate anything out of the ordinary with the HughesNet system.
Your cooperation and patience are much appreciated. Looking forward to hearing back.
- coppcabin7 years agoFreshman
Hi, and thanks for the quick replies! Power is plugged into a Tripplite Isobar surge protector. I do have other network components in the surge protector and have no problems with the other devices. However, in case the surge protector is faulty, I have also plugged the satellite modem directly into the wall outlet, but the same problem occurs.
