Liz-
-Kent
Hi coppcabin,
If you could please answer these questions as well, they can help our investigation:
Does the issue persist even when the modem is the only device plugged into that wall socket?
--A similar case from long ago involved a modem didn't like sharing a socket with a fridge, and more recently, an a/c unit.
Since you mentioned this system is in a second home, are there any devices or appliances that get powered on and used only when you're at that home?
Do you have a CB radio?
--Oddly enough, this has affected a customer's modem in the past.
The next time you lose connectivity please browse to your System Control Center (SCC) at 192.168.0.1 and click on System Status at the top of the page.
Note the State Code, which is a series of 3 numbers separated by dots. 0.0.0 is the state code for a fully operational system.
If you can't access the SCC, let me know if you can access 192.168.42.1.
Your cooperation, patience, and understanding are much appreciated, looking forward to hearing back.
Liz-
I don't know for sure what else is on the circuit, but the only other devices plugged into the outlet are a small network switch and a wireless receiver for the internet connected weather station. I will be at the home this weekend and will verify what else is on the circuit. That said, there isn't anything that is turned on in the cabin when we are there that isn't normally turned on when we aren't there. No, I don't have a CB radio.
When the lights go out on the modem and the internet goes down, I can't access anything with wireless devices since the wireless goes offline immediately at the same time. As I mentioned in the above post, wired devices can't access internet either when the problem occurs. However, I don't recall if I have tried accessing the modem management at 192.168.42.1 via a wired device or not, so I will try that the next time it goes down.
Since I will be there this weekend, please let me know if there's anything else I can check. Thanks!
-Kent
- Liz7 years agoModerator
Thanks Kent!
I have some troubleshooting steps to try when you get back to the cabin.
Try to use the internet until the connection drops. When this happens and the LEDs are off again, leave the modem alone. Give it 20 minutes to see if it will come back online on its own, so no rebooting.
If the modem never comes back online, check the state code in the SCC; it's best to try on a PC/laptop hardwired directly to the modem, same goes for trying the 42.1 address.
Finally, please have just the modem plugged into the wall outlet to see if the issue persists.
Let us know how it goes!
- coppcabin7 years agoFreshman
I wasn't able to make it to the cabin this past weekend as planned, so I will have to test the next time I'm there. Please keep this thread open. I'm not at the site very often but when I am this is a major frusteration. I will post an update as soon as possible with responses to your quesitons. Thanks!
All good, Kent, thanks for the update!
I was back at the cabin again, finally. I moved the modem's power source directly to the wall outlet. Later in the day it went offline like it always does (all lights are out on the front and internet went down). I took my laptop and hardwired directly to the modem. I didn't get an IP address via DHCP so I set a static IPs on my laptop for testing. I could not ping or otherwise access 192.168.42.1 or 192.168.0.1. However, I could still connect to other network devices that were connected to the back of the built-in 4-port switch on the modem. So when the modem goes "offline" the built-in network switch still passes traffic between devices, but the modem itself is not accessible and internet is offline. I waited nearly an hour to see if the modem came back online on it's own and it did not. I unplugged the power and plugged it back in, and as normal the modem came back online.
If it's not the power source and I've replaced the modem and power supply, what else can be causing this???
