Liz-
-Kent
Very interesting problem. I'm a retired industrial E/I computer systems trouble shooter. I've seen some very strange things happen.
Sometimes when troubleshooting, and you've done all of the smart things, it's time to try something stupid, like plugging the modem into a UPS.
I know, it makes no sense that an elecrical problem would only effect the modem when there are other devices plugged in that are not effected, but that's what I would try next.
ACCIDENT, n. An inevitable occurrence due to the action of immutable
natural laws.
The Devils Dictionary
Thank you for the input. I will go ahead and try that as well. I've tried with and without the Tripplite Isobar surge protector, but I haven't tried a UPS yet. It certainly can't hurt! Next time I go to the cabin I will take a small UPS with me.
- Liz7 years agoModerator
Hi Kent,
Thanks for getting back to me! I've created a dispatch and the local dealer should reach out to you on your mobile. I've also included instructions to have your modem shipped to us for debugging. I hope the symptoms go away with the new modem. For your reference, your case number is 117903035. Let us know how the site visit goes!
Good morning Kent,
I see the dispatch has already been completed, did the tech replace your modem?
- coppcabin7 years agoFreshman
Liz-
-Kent
Thanks Kent. Hopefully there won't be any issues, but in case there's no change, I'll make sure to put an extra special flag on my tech instructions, because we'd want to get that modem for debugging.
