Liz-
-Kent
Good morning Kent,
I see the dispatch has already been completed, did the tech replace your modem?
Liz-
-Kent
- Liz7 years agoModerator
Thanks Kent. Hopefully there won't be any issues, but in case there's no change, I'll make sure to put an extra special flag on my tech instructions, because we'd want to get that modem for debugging.
Hi Kent,
It's been a while so I'm going to close this thread, but if you have anything new to bring up, please don't hesitate to start another thread.
- coppcabin7 years agoFreshman
So it does appear that my problem was fixed by the tech that came out in January! I've been back at the property now that spring is here and after spending several weekends up there with absolutely no problems, I feel confident it is fixed. Apparently the lose connection outside between the cable that runs to the dish and the cable that runs inside to the modem was the problem all along! I haven't had a single instance since then where the modem "locks up" and all the lights on the front go off. Thanks!!
Wooo! That's great news, Kent. Glad that the tech was able to resolve your concerns. I appreciate your patience and cooperation throughout the process, please don't hesitate to drop by the community again if you need anything else, we're here to help.
