Timothy Southwa
9 years agoNot applicable
Average modem power consumption in watts?
I'm off grid and I need to know the average modem power consumption in watts when not doing much uploading or any gaming at all.
- 9 years agoGood morning,
The engineer pointed me to this page in the Jupiter install guide on pg 15, http://customer.kb.hughesnet.com/Documents/1039649-0001_c.pdf the rated power consumption of the HT1100 is 46W. That's all the info we have as far as power usage.
foxbrook
9 years agoSophomore
The power ratings on the label of a power brick are the ratings that were used when the power supply was tested by UL for safety. They may or may not have anything to do with the actual power draw of the modem. The reason for the higher input power rating, other than the efficiency loss of the circuit, is that UL requires the unit remain safe during fault conditions, such as a shorted output or a component failure within the power supply. Under these conditions the current draw can be higher, than under normal operating conditions.
Anyway, as I sit here typing this my Killawatt meter on my HT1100 modem shows it is drawing 23W at 120V input.
