Connection drops intermittently
For the last two months, I have been experiencing dropped connections on my Gen 5 system. These routinely occur during the daytime:
a) after 6 a.m.
b) occur about every 5-7 minutes
c) only last about a minute or less.
d) rebooting the modem has NO effect.
While it is a nuisance while working on the internet, it makes my telephone next to useless. Once the sat connection is dropped, the phone goes dead interupting any conversations in progress.
Any ideas to correct this would be greatly appreciated!!
Hi lcregger,
Thank you for your patience while the engineers investigated your case. They would like to get a hold of your modem and ATA for debugging, as they aren't able to reproduce the same issue on their lab equipment. I will have replacement equipment shipped at no cost to you, but I will also email you special return labels so that our engineers get your equipment.
Good morning lcregger,
I see the equipment arrived at your location last week. Have you been able to give them a spin?
A few things to try and/or make sure of....
If you have the modem plugged into a power strip or surge protector, please try plugging it directly in to an outlet to see if it makes any difference. Also, please make sure that the power plug going into the back of the modem is not loose. Please be careful with this plug, as it is delicate. In addition, please make sure that the coax connector at the back of the modem is finger tight. It doesn't need to be any tighter than this, but it shouldn't be loose.
In the meantime, if you do not normally do so, please make sure to leave the modem plugged in, as the reps may need to run remote diagnostics on your HughesNet equipment and the modem will need to be powered in order for them to do so.
The reps are on M-F from approximately 8AM to 5PM EST, though it may take them a day or two to reply.
- lcreggerFreshman
a) Modem is plugged directly into wall outlet.
b) Both power plug and coax are snugly connected to modem.
c) Modem stays on 24/7 unless I am in the process of re-booting the modem.
No difference noted in modem dropping out intermitently during the day.
Thanks for your response!
