Dashboard Indicating DNS Acceleration[N] Problem
Thank you for responding.
I tried several times to send a private message through the link you provided but I kept getting the following error:
I kept trying to send it and eventually got this message:
I don't know if you got the private message or not.
"I don't know if you got the private message or not."
Probably not. Check your Sent box. If it's not there, it never went through.
If you get the error about reaching the message limit, leave the message up on the screen and wait about 2 or 3 minutes. Then come back and click Send again. Make sure you only do one click. The system interprets more than one click, (for example a double click, something users may not even realize they're doing) as an attempt to spam the system, so it gives you an error.
If errors continue, login using a different browser and try the same procedure.
[Edited to change content]
