Data dam broke. Help
Thank you everyone. All little points worth remembering.
Bout the only game the wife plays is 8 year old 'Sims', so she doesn't need anything powerful. Nor, is she getting anything powerful. I ordered an Asus Radeon HD6450. 2012 era card, $50. *new*
Data levels holding strong. Slaying all those PUPs took care of the problem. Marking this thread as 'resolved'.
Are you sure that the machine isn't set to sleep, or turn the display off after being idle? Does this happen while it's actually in use?
Unlikely those PUP's would cause that, most the time someone that writes such things wants the machine to be used, not to disable the machine.
What OS is on it exactly, and what model computer is it? I assume hers is a desktop?
No, it isn't going to sleep. Shuts down while she is working on it.
It is an older Desktop (2012) HP P-7 1387 with an I-5 processor, running Win 7
Two reasons I asked. I have already ordered a descreet video card, thinking the problem was there. Also, since I have cleared out the PUP's, it has not shut down. That was why I was asking about them affecting a video card.
bos2420 wrote:It is an older Desktop (2012) HP P-7 1387 with an I-5 processor, running Win 7
Make sure the desktop has an adequate power supply for the addition of a discrete video card. Name brand, premanufactured desktops don't tend to install PSU's that give a lot of expansion possibilities, and video cards can be one of the most power hungry add ons.
It'll probably be fine, but it would be a good idea to make sure. Being that there are so many PSU size calculators, I won't list any here. If you search on Google for "PSU size calculator" you can find quite a few. Again, what desktop already has may very well be enough, but you always want to make sure.
BTW, if the following is what you have, you'll probably be fine, as it says it's got a 600W PSU. https://support.hp.com/hr-en/document/c03532948
Regarding the above statement, I should add that as long as it's NOT the latest and greatest video card you'll probably be fine, as the newer, more powerful ones draw a LOT of power.
Plus newer video cards require cleaner DC power than older computer PSU's supply.
BirdDog wrote:Plus newer video cards require cleaner DC power than older computer PSU's supply.
No doubt. They're definitely getting more finicky as time goes on. If I put one of the newest ones in my present setup it would probably flash a message on the screen that says, "Yeah, right!" :p
