DNS settings question for Mark, Corrosive, BirdDog, or whoever else might be able to help...
I use a Netgear router with my HT2000W. I have the WiFi in the HT2000W disabled, and run everything through my Netgear router, which is, of course, connected to one of the LAN ports on the back of t...
I've never had any issue with the meter, even when I had the HT2000W set to Google's DNS and didn't use the Netgear router.
The meter's default setting is 192.168.0.1.
Again, though, if I set the Netgear router to Google's DNS (and the HT2000W and all devices to automatic) will the four things use Google's DNS since they are all going through the router?
MarkJFine
8 years agoProfessor
Yup, pretty much. Automatic will always use whatever the next device forward uses.
