Good morning macsretandme,
Edit:
Curious, when it goes out, what is the Statecode displayed on your system status? There is no way to change what gateway facility you go through, they are hard-coded for each beam that covers a region.
- macsretandme8 years agoNew Poster
Here are screen shots of this time, 7:20 EST when the connection is going downhill fast:
this happened right before the system light went red and no connection. Then all of a sudden it came back absolutely fine until the next "cycling"???
If you know how, you shoud edit your SAN out of those pictures. That's the number that starts with DSS. That's your account number, and it's sensitive info, like your phone number or address. You should never post your SAN on a public site.
You can edit the SAN out using Paint.
yes I realize that, should've done that. But you haven't addressed my issue!
