Good morning macsretandme,
Edit:
Curious, when it goes out, what is the Statecode displayed on your system status? There is no way to change what gateway facility you go through, they are hard-coded for each beam that covers a region.
Here are screen shots of this time, 7:20 EST when the connection is going downhill fast:
this happened right before the system light went red and no connection. Then all of a sudden it came back absolutely fine until the next "cycling"???
If you know how, you shoud edit your SAN out of those pictures. That's the number that starts with DSS. That's your account number, and it's sensitive info, like your phone number or address. You should never post your SAN on a public site.
You can edit the SAN out using Paint.
- macsretandme8 years agoNew Poster
yes I realize that, should've done that. But you haven't addressed my issue!
macsretandme wrote:yes I realize that, should've done that. But you haven't addressed my issue!
This isn't instant messaging, nor chat. The reps can often take up to 48 hours or more to reply to an issue. The reps are on M-F from approximately 8AM to 5PM EST. Liz Amanda
As for your SAN, whether you edit it out of your pictures, or delete the pictures that contain them altogether, is your choice. I was simply trying to save you from a possible future headache in the form of identity theft. After all, again, that is your account number.
