Gateway connectivity loss of system every day (again)
Technician found loose pole issue with pole mounted satellite.
Relocated to shingle roof mount on house.
Corrected issue, problem solved.
Thank you for providing me that info. After running diagnostics again, I see that the signal quality is still poor which likely means the dish has shifted position. The best fix for this is getting a technician to come out and repoint the dish. Normally, we would wait for weather to clear but the weather in your area is fine. I do see some rain showers are coming up next week so you may want to schedule for a time outside of these showers or on a day that it is raining lightly.
-Damian
Okay, thank you Damian. I now have called the tech support and set up a appointment for technician to come out.
- Damian4 years agoModerator
Great, I'm glad you were able to get it scheduled. Please update me here after the repair.
-Damian
- dond_87254224 years agoFreshman
- maratsade4 years agoDistinguished Professor IV
Excellent! Glad this was solved.
