dond_8725422
4 years agoFreshman
Gateway connectivity loss of system every day (again)
Recently replaced modem. System worked great for about a week. Now, seems daily more off-line than on-line. Common Code 12.1.1 gateway connectivity connection loss, system loss, limited connectivit...
Technician found loose pole issue with pole mounted satellite.
Relocated to shingle roof mount on house.
Corrected issue, problem solved.
dond_8725422
4 years agoFreshman
Damian
4 years agoModerator
That is great to hear and thank you for the update. If you ever need anything else in the future please reach out again.
-Damian
