How do I connect a HT2000W LAN output to a D-Link DIR-655 wireless router?
First I would like to thank everyone for attempting to help out a feeble minded old man. I finally was driven to calling D-Link support. I knew that I had used this particular router as bridge in the past. BUT with my desire to keep my equipment loaded with the latest updates i had downloaded and installed the latest firmware. Some dimwit at D-Link chose to remove the bridging capability from the firmware above version 1.04. yes, there are ways to work around their attempt to force people to buy an access point and a modem but it is a pain and doesn't work well. So I did fix my problem, i used the D-Link as my marksmanship practice target of the day and found an Westel that i had forgotten about . I was up and running in 5 minutes
Have you tried setting up the D-Link router in Bridge mode?
- BirdDog7 years agoAssistant Professor
Here is a good WikiHow on it: https://www.wikihow.com/Connect-Two-Routers
You should be doing the LAN to LAN connection and don't change any DHCP settings on the HughesNet modem/router.
PS: Are you setting it up and testing with a short cable first before moving to the long one?
Might the default IP address of the D-Link router be the same as the HT2000W (192.168.0.1), causing a conflict?
ChiefMike wrote:
Thanks, but yes, that was the first thing I did assuming that was the issue. I'll try it again afrer a hard reset.If by "hard reset" you mean utilizing the reset button on the back of the HT2000W, be very careful, as it can cause more harm than good if it's not done properly.
