monicakm's avatar
monicakm
Senior
8 years ago
Solved
How Many Trips to Set Satellite Pole?
I thought I'd read that it took two trips.  I have an appt. for a new pole replacement next Tues (was for tomorrow but I called to postpone due to Easter plans).  When I postponed the appt, the installer said it would only take one trip.  How many trips does it take for a CORRECTLY installed sat. pole?
Thanks
  • Takes only one trip...  The installer should dig below the frost line for your area, and have enough cement to completely fill the hole.  He will do a "dry set".  After about 30 minutes it should be solid enough to mount the dish provided it's not too windy that day.
    My installer had to wait an hour for it to stiffen enough due to winds being too risky.
  • C0RR0SIVE's avatar
    C0RR0SIVE
    • monicakm's avatar
      monicakm
      Senior
      Thanks Corrosive.  I wish I knew where I'd read that but I'm glad it's not the case.
    That's good news.
