Intermittent no system light on HT1100 modem
My ht 1100 has been doing the same thing, usually around 1-2 pm. I thought it may be outside heat temp. My modem doesn't feel hot but I turn it off for 30-60 minutes and system light and Internet comes back. I think yesterday it took longer.
This seems to have started after the modem did some kind of an upgrade on 7/13/17. The strange thing about this, the menu item in the Advanced Menu where I saw the upgrade is not available now that everything is working.
I'll pay more attention today, it has only been mildly irritating so far.
I've got green check marks all the way across top to bottom for 48 hours in the diagnostics. I don't think it is anything I did but appears to be fixed.
- AedanSenior
Hello duke_mabank,
Thanks for posting. I pulled up your account to troubleshoot, but we are unable to communicate with your system. Please ensure that your modem is turned on and that all cables are securely connected. Thanks, and please let us know if this issue continues.
-Aedan
- duke_mabankSophomore
Aedan, the system light may have been out when you tried to communicate with my system. At 3:13 central time, I clicked on a link and nothing happened, went and looked at the modem and the system light was out but it came back on a few minutes later.
We won't worry about it now, I still think it could be heat related. Maybe my modem is getting hot since my living room is 85 degrees and even though my modem is on a table with nothing around it, my a/c is working hard to cool.
duke_mabank
It's more likely the modem, or ODU are going bad actually... I have an HT1100 sitting inside a server closet where the temperature easily reaches 90F and the terminal hasn't gone down yet. They do build these units to handle a fair bit of heat before they will have issues, and if it's an overheat issue for the modem, then the modem will power down and the power light or system light will go solid bright red.
If it was an ODU overheating, we would have many more complaints about the system light going out due to the extreme heatwave that has hit the country.
- AmandaModerator
Hi duke_mabank,
I've moved your post so we can work on your issue in a separate thread. I was able to run diagnostics on your equipment but before I accept the diagnosis, I want to check in a few things first. I know something like this has happened with your modem in the past and we had it replaced, so I find it troubling that it has come back. I can see the modem is not overheating, you are running at an average of 123 degrees farenheit and the modem's threshold is 175 (your highest reached is 127). If the modem does overheat, the power light will turn red on the front of the modem.
So before we do anything further, it would help to know a bit more about your power situation there - I am not sure if we had that discussion before. Do you have the modem plugged into a power strip, surge protector or utilize some type of unconventional power source like a generator? Also, please carefully check that the coaxial cable from your modem to the wall and the outside wall to your dish are secure and not corroded or frayed.
Thank you,
Hello Amanda,
Last Friday I was about to hit send with the answers to your questions when I got a text from AllPro Satellites wanting me to confirm a Saturday Morning appointment. I called them and talked to Jonathan, the install manager.I described the problem I was having and told him I needed a few days to check some things on my end and if he would, put the appointment on hold which he did.
The questions you asked about the power and if I was on a surge protector made me think that very well could be the problem. Because it has been on a 2160 joules Philips surge protector for 17 months, I thought I would try it direct to a power outlet.
So, Saturday it went out briefly at 1:30 pm while I was streaming an internet radio station and by checking the diagnostics I saw that it went out for a few minutes early Sunday morning. Those outages are not a big deal to me and I though it was pretty much normal, so I thought my problem was in fact a faulty surge protector.
Sunday, at almost the same time, about 1:30 pm it was going on and off for about 45 minutes. It has always been around that time of day. Friday It was out at 11:00 am but it seems to always be between 11 am and 2 pm which makes me think that it is on my end.
And did I say that I put the modem direct to power? Well, it is on a 50 foot 16 gauge extension cord that is plugged into a laundry room outlet. That outlet is on a double breaker to make it 240.
When I lost power in the 2 living room outlets back in May and moved the surge protector to the extension cord to the laundry room, that could have been the beginning of my problems.
What do you think? Are extension cords bad for a Hughesnet modems?
- 4 months ago
