Intermittent no system light on HT1100 modem
I've got green check marks all the way across top to bottom for 48 hours in the diagnostics. I don't think it is anything I did but appears to be fixed.
Well, I am no electrician and I may have trouble tracking someone down in here that would be able to give me an answer but I will tell you a short story of a customer I had in the past...
They had a similar set up as you, except the modem was sharing an outlet with their fridge. When the fridge would turn on to cool, the modem would lose power. Keep in mind that the radio transmitter on your dish is being supported through the modem's power source too. Other setups like power strips or surge protectors may create low power situations that impacts performance (slow speeds, intermittent connection).
Good example of why it's always good to have things like compressors and heaters on their own service to the breaker box. The load when it kicks in probably dropped the line voltage below the threshhold that the modem's power supply required. Kind of like when your lights dim slightly when the air conditioner cycles on a hot day.
