Gwalk900, GabeU, BirdDog, C0RR0SIVE, MarkJFine, I'm sure this is a stupid question, but, does an extender work with the 5GHz broadband??
maratsade wrote:Gwalk900, GabeU, BirdDog, C0RR0SIVE, MarkJFine, I'm sure this is a stupid question, but, does an extender work with the 5GHz broadband??
Sure, but like anything, not good to go with the cheapest available and do some research. Depends how far and how fast you wnat to go.
https://www.tomsguide.com/us/best-wifi-extenders,review-2225.html
Thanks, all. I thought that if the 5GHz band goes, say, 10 feet from the modem, then an extender in that area could extend the range another few feet, though I don't know how many it would be.
From what I've read I believe so, but it all depends on the extender. Plus, I imagine that while utilizing an extender with the 5Ghz band it would still be short in range, like the source 5Ghz signal.
Edit: BirdDog posted while I was typing. I defer to him.
