nathangilbert
8 years agoFreshman
Link speed
Noticed that my link speed went from 72mbps down to 54mbps about a month ago. With the slower link speed I cannot stream any video. Gen 4 equip, 1.6 years old. What would cause this? Guess I don't hav...
Hi Nathan,
When you say "link speed" are you referencing a certain test result or your local LAN link speed? Both 72Mbps and 54Mbps are off the charts high for Gen4, so it would be good to get a little more information.
8 years agoModerator
Hi Nathan,
- nathangilbert8 years agoFreshmanI must be looking at wifi link speed. Just ran a speed test and came up with 17mbps
What is the result you get when you run the test in the following link? http://192.168.0.1/limited.html#!/general/lan_speed
