Modem issues after power surge
Hi Gigix2,
Thanks for posting and welcome to the community! Thanks for confirming that your modem was still plugged in. I tried to run diagnostics on your site, but I'm not able to make a connection; looks like that surge got your modem. I'm sending you our latest modem model, no need to return your HT1100. Here's our guide to replacing and getting started with your new modem. Please expect the modem to arrive in a few days.
Gigix2 wrote:
It happened about an hour ago and I do not have Gen 5Ah. Okay.
It may very well be that something bad happened to the modem or radio when you had the power surge. Are you showing any state codes on the following page?
http://192.168.0.1/limited.html#!/state_code/state_code_monitor
If so, what codes are showing?
- Gigix28 years agoFreshmanI can not open that link on my cell. Is it supposed to be open through Hughes net connection?
Yes, you are supposed to use that link on a device while connected to your Hughesnet modem... If you have an HN9000 or HN7000... the URL will probably be different.
