Since the morning of August 11th, ive been having severe speed issues. I barely get more than 20kbs when downloading, im having a lot of trouble loading anything on Facebook, cant use Youtube, so forth for so on. The last speed test ive done using the speed test on this site says my download speed was 0.35, and upload was 2.36. Im out of data in the day time, but ive still got about 3GB of night time data, as in, as I post this. I was barely able to get to this website
Ive rebooted my modem several times from the control panel, and ive unplugged it, let it sit for 10 minutes, and replugged. No improvement. My signal strength is 105 as I post this, there are no weather issues in my area, and my modem is looking perfectly fine, as in, no strange lights or anything
Furthermore, on the morning of the 13th after about 10AM, it picked up speed and ran at normal speeds. Having the same issues on another computer thats directly plugged into the modem. I havent tried using other online devices to check it though!
So is there maintence or issues at Hughes?
Thanks for your time! Hope this can be fixed, this is barely better than dial up right now
Edit: https://testmy.net/quickstats/DanKaiser
Heres my speed stats, im doing further testing! At this point, as suggested, ive stopped doing the testing since im in FAP condition, and with the 25MB size, its not even downloading. Speeds are at 40kB/s, and theres a lot of issues connecting. Still no obvious issues with my modem, and the speeds are the same using wifi or a wired ethernet connection, and ive tested on multiple devices and multiple browsers. The issue started sometime last week, and was fairly transitory, but became worse. On Saturday morning, when I made this topic, it fixed itself until 4AM Monday morning, after a storm rolled through. My current state code as of this edit is 24.1.1, but I had data during the beginning of the slowness issues so that should not be the issue. Hope we get some investigation going soon!
Go to the modem's page (http://192.168.0.1/#!/home/status) and post what the number next to State Code is, especially at times when the speed is so slow That will provide some information about what may be going on.
You will also need to post the URL to your My Results page from Testmy.net.
- Danny89Junior
As of now, my speeds are normal, that started at 6AM
My state code was either FAP Condition or Fully Operational, the whole time. Its been 0.0.0 Fully Operational since 2AM, even when I was unable to load a webpage, and if I attempted to download my game from Steam, it would hold at less than 20KBs(At 6AM when it came back to normal speeds, it went up to 900kbs and even peaked at 2.5MBs!)
I'll post the speeds from TestMy if the problem starts again. Hopefully it won't, but it did this yesterday where in the morning it suddenly fixed itself..and then by night it was extremely slow to the point of not being usable, which is what makes me think theres some other issue. Oh, and I checked further devices, and they all reported the extremely slow speeds during the...slow time
Im having flashbacks to when i was on dial up
Edit: Getting some baseline from TestMy if needed!- maratsadeDistinguished Professor IV
Let's hope it was a transitory thing, but getting some baseline speed tests would be a good idea, and then running tests if the issue comes back. Hopefully it won't, at least during the weekend.
- LizModerator
Hi Danny89,
Thanks for posting and working with the community regarding your speed concerns. As maratsade mentioned, trying to run speed tests while subject to the Fair Access Policy won't be useful. So, I've sent you a data token to use at your convenience and run tests then. I also ran diagnostics on your site and aside from being out of data, the HughesNet equipment is working normally.
I understand that you noticed slow performance even on another PC directly plugged in, but just wanted to point out that this "HP709499" device that's on the 2.4 GHz network only has a fair signal strength. I suggest moving it closer to the modem or even directly connecting it to the modem.
Let me know once you've run some new tests after using the data token so I can check them out on your TMN profile. Thank you!
- Danny89Junior
Thanks! I'll begin testing soon! Just got online
That device is a printer on the far end of my house, shouldnt be of much trouble
Edit: As of right now, with a short burst of tests at 25MB, its running perfectly fine. I'll keep it up over the night and morning to see if its ok!
Edit 2: Its holding very good speeds while I have data. Need to keep a watch on it for a couple of days, but either the throttle was being very cruel to me compared to usual, or the Modem needed to be contacted. Hopefully it'll stay up and when I run out of the token data, run like it should when throttled normally. That ultra slow speed was very close to not having internet at all!- LizModerator
Gotcha! Good to hear that things are running speedily again on token data. It just can be tricky on reduced speeds since speeds (reduced or not) can and will fluctuate. I usually see speeds fluctuate by 2-3 Mbps, but I've also seen changes of over 10Mbps. So when your speeds are reduced and have already a small range to work in, seems to me to be a challenge to consistently stay on the higher end. Especially if you have multple devices on the network; imagine splitting up 2 Mbps across 3+ devices.
