Hunter74083
8 years agoFreshman
Modem Lights go off HT2000W-System, Transmit & Lan
Every thing stops when lights go out. Dont know when they will do it. Wrote tech sup, asked to get call back by 5pm friday, recieved the following Thursday. So hard to get ahold of them. Ready to ...
Thank you very much Felicia. System is running like it should now. Tech knew his systems. Thank you again..
Hunter74083
8 years agoFreshman
Couldnt get the state code button you posted to work.
MarkJFine
8 years agoProfessor
Hunter74083 wrote:Couldnt get the state code button you posted to work.
Ok, then guess we do it the hard way... Try clicking on the gray "i" to the right of the "English" at the top, which should bring you to an advanced menu. Then "General", and then "State Code Monitor" on the left.
Edit: Already concerns me that the firmware says "2017" at the bottom. Could swear it's been updated at least once this year.
Edit2: This would take care of #s 1 & 2, but still need to know the answers to the rest of the questions, since everything else seems to look normal right now.
