HermanC's avatar
HermanC
1 year ago
Modem no system and no transmit lights
    Leave it plugged in so the reps on this site can try to contact it remotely.  If they can't find your information through the community, they will post a link for you to send them a private message with your account info.
  • HermanC,
    Thank you providing that info. There seems to be virtually no information on our side about a history of issue or state codes. I can, however, see that the transmission has stopped or been interrupted. This means I will need to get the current state code from your modem control center. In order to find out what is happening to the service, we will need to obtain the state code. If you see lights on the modem where "WiFi" or "LAN" are labeled, you will be able to access the modem's control center. This is where we will be able to locate the state code. To do this, open any browser you would like on a computer or device connected to your Hughesnet modem. In the address bar at the top of the page, type in 192.168.0.1 or systemcontrolcenter.com. This will populate the control center for your modem. At the top of the page, please click on the "System Status" link. The next page will load where the state code will be displayed in the first information box. Your state code should be in a format such as "0.0.0". -Damian
      • Damian's avatar
        Damian
        HermanC,
        Thank you for that info. This state code is usually associated with the dish being moved out of alignment either physically or by weather. It can also mean the cable screwed into the back of either the modem or dish is loose. I recommend checking the connection and making sure that the cable is screwed in snuggly as well as looking to see if the dish seems out of place compared to before this issue happen. If the dish is out of place and a power cycle of the modem does not work or the cables have been damaged, having a tech come out to repoint the dish or replace cables would be the next step . -Damian
