Modem Problem Solar No Communication
eco,
For reference, while signed in, if you click on Remy's name, then click "Send this user a private message", a box will pop up. Wait a few seconds before doing anything in the box, as it can take a couple of seconds for his name to be populated, then give it a title, then the PM.
The PM system is kind of odd in that, if the name population is delayed and you immediately start typing a title when the box comes up, it can mess with the name when it finally is populated, so it's best to wait until you see the name appear if it isn't already there.
eco,
Thanks for reaching out! In regards to your ongoing issue with your SolarEdge system, I've had this case sent up, and we'll have our engineers take a look into it. We'll reach out if we have additional questions, or as soon as we have more information on a solution! I've also gone ahead and unmarked the previous post as well...although in my world, cats are always the solution!
Remy
Remy, I tried to reply using PM , entered your username , it disappears.
Anyway the problem appears to be resolved. All 1's in the codes, and I have no idea of what you asked. I refer you to the message from the Solaredge tech. I swapped the modem ports #1, and #2, then back .
eco,
