No speed, loses connection, buffers continuously
tech cme yesterday an repointed my satellite, It is still getting varying spins but they are between 14 and 33mps, The 14mps was durging rainstorms yesterday. So far it looks good. Thankyou for all your help and I am closing this thread as solution and see how it goes
First, please check to make sure that you are not presently out of data (you shouldn't be after two weeks, as you should still be in the initial 20 day unlimited data period), which you can do via the HughesNet Usage Meter or the System Control Center. Also, please verify that both boxes at the top of the System Control Center page are green. If you are not out of data and both boxes are green, please proceed with the speed tests described in the following instructions...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share the account results link with us here.
-use the 25MB size download test file
For a more in depth guide on running the tests, please see this site (due to being an older site, the stated test sizes are incorrect for Gen5 (please use the test sizes listed in the instructions above, in bold, for Gen5)).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
both green lights on .4 gb used. this morning I actually had a download speed of 27mb. i have speeds varying between.78 kbs and 28 mbs with the high speeds today the rest have been low. <a href="https://testmy.net/quickstats/my speeds">my speeds's Speed Test Results</a><iframe src="https://testmy.net/quickstats/my speeds&f=1" scrolling="no" frameborder="0" height="380" width="100%"></iframe> If speeds as they have been I cross my fingers that I get an average acceptable speed.
If the following is your link, please be sure to start using the requested manual test sizes when running the tests.
- baww427537 years agoFreshman
Still battling speed ntest good and 5 minutes later it has slow speed.. I am not tech savy but there is something wrong here.<a href="https://testmy.net/quickstats/my speeds">my speeds's Speed Test Results</a><iframe src="https://testmy.net/quickstats/my speeds&f=1" scrolling="no" frameborder="0" height="380" width="100%"></iframe> This is rediculous. Internet is close to nothing. cant load facebook, shopping, or data sheets.
The links you're providing aren't working properly, as you can see in your replies. That's okay, though, as the reps only need the link to your Results page, and it only needs to be posted one time, as it always shows all tests that have been run thus far. I'm 99.9% sure that the link I posted is to your tests, as I see that the proper test sizes are starting to be used.
So that the reps know for sure which test results are yours, please verify if the test results in the following link are yours. Again, I'm 99.9% sure that they are, but I want to be 100% sure, for the rep's sake.
test results with 25mb download and upload <a href="https://testmy.net/quickstats/my speeds">my speeds's Speed Test Results</a><iframe src="https://testmy.net/quickstats/my speeds&f=1" scrolling="no" frameborder="0" height="380" width="100%"></iframe>
In order to get support, please follow the advice Gabe gave you above. Post the link to your results page, and use the 25 MB manual size for downloads.
