How to read:
The number at the left is the hop number.
Hop 1 is 192.168.42.1, your modem.
Hops 2 and 3 are the HughesNet path to the gateway (thought there should be another one somewhere).
Hop 4 is Qwest (now owned by CenturyLink), your gateway provider.
Use 525mS as an easy to remember guide, because the radio path takes that much time to go to from you to the satellite, down to the groundstation, and then the return trip back to you.
These are all showing about 1-1.5 seconds more than that, which sounds to me like either a network compatibility problem or simple network congestion (congestion being too many users, causing a processing/routing backlog). CenturyLink is well-known for sporadic 1-minute gaps in service, not 1 second, so it's not the provider.
It could feasibly be peak time congestion, but it'd have to be pretty congested and I'd have to see what one of these looks like during a non-congested period. If it's that high (readings of 1500-2000mS) during non-peak time, then it's not congestion, it's a network compatibility issue.
But again, I don't know what tracepath is actually doing. I'm working from the assumption that it's something similar to traceroute and I might be wrong.
